Problem with screen swipe to the right
  • Start date Start date
A
Android Central Question
I have a Lg Premier pro plus. It has 3 screens and a lock screen. Suddenly the swipe right has turned into a white page with a google symbol at the top and all my apps have been moved to the second screen. I have no Idea how to fix this? Can any one help?
Welcome to Android Central! Are you using the stock launcher, the Pixel launcher, or something else? You're seeing the Google Discover page, which is standard on the Pixel launcher and some others.
Try long-pressing any empty part of the homescreen, and look for a Homescreen Options button. Tap it, then look for an option to turn off the Google Discover page.
Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/ask-question/409154-join-android-central-community.html
Deinenxo
