Odd Battery behavior
  • Start date Start date
A
AC Question
The Galaxy tab 2 - 7 is less than a year old. It has been fine until yesterday when it drained completely overnight. It was at %100 when I turned in and at %2 in the morning. It also will not charge to %100 now, it stops at %99 and holds for hours even with charger on. USB charging...takes hours.
Could you send a screenshot showing what's using your battery...or is battery use now back to normal?
Remsangpuii
