A
AC Question
Help finding a Clock/Weather/Alarm/Battery widget
Hi,
I have a new LG G3, always had HTC previously.
I'd like to have a homepage widget that shows time and weather, and ideally battery life as a number/percentage. I'd like it to be interactive - i.e. touch the time and I get taken to the alarm and clock functions, touch the forecast it opens the weather app etc.
I thought Id found the solution by paying for Zooper widget pro, then downloading the LG smart skin for it. But it doesn't seem to work - just gives the weather on its own.
I guess using Zooper I could spend hours designing one, but I'd rather not as I'm sure there must be something already out there!
Thanks
Hi,
Thanks
