Can I get some help with a Galaxy S 3 with some battery drain issues?
A
AC Question
Hey I have a galaxy s 3 with some battery drain issues, so I reset it to factory mode but it
comes up with
wiping data...
E:fomat_volume: make_extf4fs failed on /dev/block/mmcblk0p15
formatting / cache...
E:fomat_volume: make_extf4fs failed on /dev/block/mmcblk0p17
Data wipe failed.
---Appling Multi-CSC...
E:failed to mount /system (Invalid argument)
can't mount '/system
and on and on it goes
How do I fix this?
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,407
271
83
Re: Hey I have a galaxy s 3 with some battery drain issues, so I reset it to factory mode but it
Is the battery so bad that it may be causing that? You've got the phone connected to the charger?
olalekan45
