I'm using PanasoniC Eluga S ,HaVing Proximity Sensor Problem
  • Start date Start date
A
AC Question
I'm using panasoniC Eluga S mobile and at tHe beginig of tHe puCHase it was working well
and later proximity sensor was not working
wHere an i find proximity sensor setting in it????
Welcome to Android Central!
Try getting a can of compressed air and lightly spray the earpiece of the phone. There could be some dust in the case that is causing an issue. Be sure not to spray directly or too close to the earpiece so you don't damage it.
Winnie
