Why won't my S6 Edge connect to my phone network provider
nick9853
3
I've just got back from holiday and my s6 edge won't hook up to the three network. It worked fine in France but when I got to Dover and it should have gone back to 3, it just says cannot connect, try later,and emergency calls only. It works fine on wifi but even after a factory reset it still won't connect to my network. It was quite hot in France, but I tried to keep it out of direct sunlight. Any ideas please? It didn't have any errors on screen either.
Welcome to Android Central! Try Settings>Mobile Networks>Network Operators. Does that give you a list of available networks, and can you select Three there?
Hi, it finds the networks but won't attach to any. Just says can't attach to network, try again later. I've tried again this morning with the same result :(
I guess he did as he has not been here since early September. I think you should start a new thread detailing your issue so we can help you get back up and running
Crissy Doug
