N
Naturalgal 99
Its reboots at the LG onscreen logo. Shuts down at thatpoint the n powers back up over and over. I have done the estart to factory reset.went right back to same bootloop.any suggestions?
Unfortunately I don't think there is. I was going to suggest a reset, but since you already did and it's still rebooting the problem may be deeper. Can you replace the battery? Sometimes that seems to be the problem and a new battery will fix it. It's probably the cheaper fix before sending it to LG (if that's an option) for repair or replacement.Its reboots at the LG onscreen logo. Shuts down at thatpoint the n powers back up over and over. I have done the estart to factory reset.went right back to same bootloop.any suggestions?
