Can't connect to my wlan on my huawei mediapad t1 8.0 pro. Keeps trying to get IP adrress.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Check the router (from a computer). Make sure there's space in the DHCP server. (If you have the lowest address set to 250, and you have 4 devices connected, there are no more addresses for the router to give out. The same if you have the highest address set to 5 and you have 3 devices connected [1 is the router itself - 0 and 255 can't be used].)
Also, make sure you don't have the phone set to use a static IP address - if that address is wrong (you have to manually enter it), it won't work either.
smokedog87
