help pls. - problem with installing a theme ? on Touchwiz 6 S7 / S7 edge
TJ Cee
I am using Touch wiz 6 on S7 / S7 edge, I can install Samsung Theme store themes fine - but I am getting tied in knots trying to install a downloaded theme system wide
that then loads with Action Launcher or Nova Launcher for further tweaking.
I need to understand what comes first e.g. theme install > open launcher > tweak . . . .
or other ?
I know there may be limitations under Touch wiz 6 of themes available, but is it possible to grab a launcher compatible theme from Play store then install and load chosen launcher ?
Hi, that's a good question. I would imagine you would need to download the theme first, from the Galaxy store - install this and then download a custom launcher from the play store, like Nova or Action Launcher 3. Give that a bash and let us know if it works :)
p.s. welcome to Android Central :D
niv141
