batman theme on regular samsung s7 edge
iammuddii
I have samsung s7 edge regular edition (non-rooted) , I tired so many time to apply batman theme on my mobile,
I install batman theme and apply it, and disable theme store and theme center by package disabler pro,
but just after 5 or 6 mins, batman theme trail ended and default theme apply automatically.
what should i supposed to do now??
Make sure you clear the cache of the two applications you disabled in the package disabler after you disabled them. Should work like a charm afterwards.
Posted via the Android Central
Yes make sure u clear the cache of both apps and just press home button to exit package disabler then remove it from recent apps
posted from Limited red and gold Lumia 950, Beautiful S7 Edge gold or Surface pro 4
I have used many of the ones off XDA (Batman, RoboCop, Civil War etc) and I did the same steps you did , and they stick for me when I disable the store and the themes
Did you pay for the theme or were you using the trial. The trial only lasts for 5 minutes and then it reverts back to the default theme.
That they do but when you disable the 2 packages, it doesnt expire (mine doesnt but this is how it is supposed to work)
Loving the batman theme on my s7 edge ...really kool...no need to buy batman edition s7 edge 😜
Hi. Am not so techy. How do I cleat the cache of the 2 apps
Press and hold on them and it will show options of disable and clear...
1st disable then press clear
Are people disabling the theme store after applying a theme to circumvent the trial time period? If so, that's weak. Pay a few bucks for a developer's time.
I know on XDA, there is a Batman apk being offered there that people can install on rooted phones. This might be what some people in here are referring to.
These themes are not available on the store
package disabler pro not working
now it cant hold the batman theme for more than 5 minutes
any solution guys ?
Read my earlier comment
Posted via Limited Edition Lumia 950 with Mozo Case or Beautiful Gold S7 Edge or Surface pro 4 or Lumia 1020 or motoe or iphone 5s
johan mayhew
