B. Diddy Senior Ambassador Moderator Mar 9, 2012 169,175 10,395 113 Jun 15, 2016 #2 Welcome to Android Central! Do you know if you've set it to block those numbers? Or is it all numbers that are going directly to voicemail? Upvote 0 Downvote
Laura Knotek Moderator Captain Moderator Jan 8, 2011 13,538 9,184 113 Jun 15, 2016 #3 In your call settings, do you have it set to forward all calls to your voicemail or to forward calls only if you're unreachable? Upvote 0 Downvote
