Why does my flash notification get stuck?
I have my flash notification turned on. Sometimes when I get a text message the light will flash like it's supposed to but then it stays on like a flashlight. The first few times it happened I tried turning off flash notification to see if the light would go off and it stayed on. I had to restart my phone before it would go off. Why does it do this?
Re: Why does my flash notification get stuck?
What phone are you using? Also do you have the "Light Flow" app installed? I have been doing some research on your problem, and some of the threads mentioned issues with that app, so IF you have it, try getting rid of it and seeing if that removes the problem. :)
