Phone will not access Contacts... Help!
  • Start date Start date
A
AC Question
I have a Motorola Turbo 2 running Marshmallow. When I go into any program to try and access Contacts, it asks for permission, which I choose "Accept". It refuses this and will then state that permission was denied.
I had previously installed a dialer/contacts manager app (forgive me .. Don't remember which one) but I hated it and uninstalled it. After that was when this issue started. All permissions for Contacts are turned on in Settings.
Anyone?
Since it's not working in Safe Mode, I'd suspect something wrong with the firmware. Backup or sync as much of your data as you can, then try repairing the installation: verizonwireless.com/support/knowledge-base-116950/
Maybe reinstall the offending app again and see if you turned on some nasty setting.. After problem is sorted, uninstall the app again?
sevogas
