C Chaitanya Sharma New member Oct 11, 2016 2 0 0 Oct 11, 2016 #1 I cannot download the mms messages. Can somebody hel' me out. Appreciate it yaw. BTW I'm using the expensive S7 EDGE
the tall guy Q&A Team Sep 23, 2013 7,210 1 0 Oct 18, 2016 #2 Hi and welcome to AC have you spoken to your carrier? they might have disabled this feature. Upvote 0 Downvote
B. Diddy Senior Ambassador Moderator Mar 9, 2012 169,696 11,115 113 Oct 18, 2016 #3 Welcome to Android Central! Is your mobile data turned on? MMS requires mobile data to be on -- it doesn't use voice signal or wi-fi. If you didn't get the phone directly from your carrier, you might have to check the APN settings to make sure they're configured correctly. Upvote 0 Downvote
