A
AC Question
I recently dropped my HTC Desire 820 G+ flat on the ground. The view got disturbed and then turned off. Now it doesn't turn on. There are several cracks on the screen. When I plug in the charger, the charging LED light doesn't flash like it usually does. Does a cracked scren prevent a phone from turning on? Is the problem only a cracked screen or somethong else aswell? Because I can replace the screen but I want to know if its just the screen that causes the problem.
