Is it bettary problem?
  • Start date Start date
A
Android Central Question
When my Redmi note 4 mobile battery is 60 % or 50 %, that time my mobile phone is not changing but when my mobile battery is dead that time mobile charging, what is the prblm plse tell me.
Welcome to AndroidCentral 😃 I presume English is not your home language but thanks for trying.
I'm not sure what the problem is. Does your phone only charge when the battery is at 0% and not when it's 50% or 60%?
That could be a software bug and doing a update might fix it.
And you should never drain the battery to 0% - it won't last more than a few months if you keep doing that. When it drops to 40% (50% is even better) plug the charger in. And wait at least 15 minutes before you say it's not charging.
As Matty said, it could be a software problem, but it also could be a hardware problem. It's least likely to be the battery itself.
Music
