I have problem, please help me.
  • Start date Start date
A
Android Central Question
I have htc one m9. It doesn't support 3g or UMTS only supports 2g or GSM. If I select UMTS only then no network coming.
And another problem is that, when I press recieve on shareit app it says, "Allow only one connection while roaming on gsm network".
What is the solution, please help me.
Have you spoken to your carrier about the first problem?
I know nothing about the app you mention, though others here may.
Carlos111
