Help ! Deleted Fire UI...
xpun3414
6
Hi guys. Looks like I deleted the Fire UI. Now, I dont get pop up messages. I dont have the notification bar or the soft keys. And now that the pop up boxes wont pop up, I cant authorize the tablet. Which means I cant do any modding to it, to fix it. Just dont know what to do at this point. Any ideas would be greatly appreciated.
-Kindle Fire HD 10 7th Gen.(2017)-
Welcome. :)
Which device?
That should be system protected from deleting, unless you have root access. If you aren't rooted, have you tried a restart?
I did root it. for some reason I thought, since I had nova luancher installed I could remove the fire ui.... Guess not.Oh, and. Cant seem to find the systemui apk.
You'll most likely have to reflash the original ROM. I'm not sure if you can find the system UI application separately.
I have the .bin file but cant install it. no way to installl it through recovery as it only has the ADB sideload for that type of thing. & cant install it in the fire os since its a bin file.
... Yeah. Screwed this one up, good.
Adb isn't hard....just intimidating for those new to it.
You can try it, you would need to enable USB debugging in developer options, and have adb ready on your PC. You would need to reboot into recovery and there should be an option for adb sideload, or I think update through ADB.
Loki Samhain
