OTG Digital Microscope / Camera Problem
  • Start date Start date
A
Android Central Question
I have connected a digital microscope to my tablet through the OTG interface and I downloaded several programs to run the microscope but all of them do not work showing me a black screen without displaying the image
What I do, please help me
Note: The tablet from Samsung Galaxy Tab lite: T116NQ and I have connected the webcam but the same problem
Unfortunately a camera isn't a standard USB device supported by Android's stock system, which means that only apps that are coded specifically to use them (think of them like drivers for a PC) can, well, use them.
Are you certain the app you downloaded is compatible with that specific camera or Android OS? Do any other OTG devices like USB Sticks work OK?
sakhe
