A
Android Central Question
I kept my old galaxy S5 phone to use offline. Lately I've been having a ton of issues. I'm not sure how to tell if it's the battery or the phone is just dead.
Having issues like:
1. Battery drains super fast.
2. Blank screen when turning on. I have to take the battery out and only put it in when I want to use it.
3. Things just dont want to work. Sending stuff through bluetooth, plugging in a charger, turning a setting on/off is laggy. It will either take minutes to do it or wont do it at all.
It's also got screen burn on half the screen. I dont want to waste money on a new battery if it doesn't work. And I also dont want to buy a used S5 if mine only needs a battery replacement.
Having issues like:
