Hear iam using Android 1606 but incoming call ringtone is not working Please help me
  • Start date Start date
A
Android Central Question
There I went in setting and then volume I increase the volume of incoming calls and select a ringtone, while selecting the ringtone, it doesn't ring as sample for me then I downloaded a music and set it as ringtone. But doesn't happen. Please help me
Welcome to Android Central! Do you mean i606? Is this a Samsung phone (which means it's an S3 mini)?
Do preinstalled ringtones work? If it's only a problem with custom ringtones, where are you saving the custom tones? They should be on Internal Storage (in the /Ringtones directory), not the SD card.
chloemccourtuk
