share location connection drop ''socket close'' problem under android
  • Start date Start date
A
Android Central Question
windows 10 pro with a share media folder location ''full control'' protect by username and password
I am using X-plore to access my share location
all my android device are able to access copy create and remove files from that location.
The problem:
every 10 to 15 minutes when i am watching a tv show i get a socket close error from x-plore. to work around the situation i just have to enter my credential and am good for 10 to 15 minutes
Never had that issue before was working few week/month ago
Here what i try so far
different share location
different android device
turn off firewall and AV on router and computer that have the share
Try with total commander and ESexplorer and same happen
I had a look under event viewer nothing seem wrong
Disable smb 1.0
use smb 2.0
all those test result with same error/issue
test to do:
I will test a laptop with windows see i have the same issue
to my knowledge nothing change on my router or computer
aimalee
