I'm at my wit's end trying to find a solution online, so I thought I'd join this community. Thank you in advance!
So I have a OnePlus 6t that I absolutely love. No bootloaders or jailbreaking or hacking, and all software and apps are fully updated. I want to use it to play music at my desk at work, so I bought a Tribit Maxsound Plus portable speaker. But it's not working!
For reason's I won't go in to, I can't use Bluetooth, so I have an aux cable plugged in to the back of the speaker and then plugged in to a USB-C-to-Aux dongle, and then in to my phone. I am getting no audio output to the speaker. Here are things I have tried to troubleshoot and that I know to be true to narrow down the list of problems:
- The phone plays music just fine from its onboard speakers with no other accessories attached
- The phone recognizes that a dongle is plugged in as a headset by showing me the headset icon at the top
- The music player on my phone shows that the audio track is playing, even though no sound is coming from the Tribit speaker when I use the USB-C-to-Aux dongle and aux cable
- The Tribit speaker does work fine when music is played from a different phone with a 3.5mm aux output
- The USB-C-to-Aux dongle does work on my phone when I plug in regular, 3.5mm wired headphones into the dongle
- Audio plays fine from my phone when using USB-C headphones
- I've checked to make sure all of the connections are firm and all of the wires and dongles are working in other instances.
- I've tried switching out dongles and wires for other examples, including the dongle that came with the phone.
It is my understanding that a passive USB-C-to-Aux dongle should work on the 6t because it has an onboard DAC. So I don't think it's a question of having a passive, analog dongle instead of an active, digital dongle.
Through process of elimination, I think I can claim that the phone, the USB-C port on the phone, the dongle, the aux cable, the speaker, and the aux port on the speaker all work. So it's most likely not a hardware problem. But for some reason the speaker is not picking up any audio signal with this certain combination of connections.
Any ideas? Is my logic sound? Am I crazy? Thank you in advance!
Dave
P.S. - I know there will be an urge to tell me to just use Bluetooth. I promise that I can't for "reasons" and I'd rather not muddy the thread with that topic. Thanks!
P.P.S. - If I say or type the word "Dongle" one more time I am going to lose it.
Dave
