[K]IN3TX v1.0 |12/8/11| help!
LDubs
645
34
28
From the OP at rootzwiki:
|ROM| [K]IN3TX v1.0 |12/08/11| - RootzWiki
INSTRUCTIONS FOR INSTALLING THE BASE FROM ANY OTHER ROM
WARNING!!! REMOVE ALL FOLDERS OF UNTHROTTLE FROM YOUR SDCARD (INTERNAL AND EXTERNAL BEFORE FLASHING THE BASE!
IN CLOCKWORK:
WIPE DATA/FACTORY RESET
WIPE CACHE
UNDER MOUNTS AND STORAGE, FORMAT SYSTEM
UNDER ADVANCED, WIPE DALVIK
INSTALL AND HOLD TO THE PHONE WITH BOTH HANDS. :)
ok so what this means (and I'm already assuming you're rooted):
-- make sure you download the base, add-on's and any theme paks (tpax) to your external SD card
-- install Bionic Bootstrapper from the market
-- click on first icon and wait for "Success!"
-- click on second icon to reboot into ClockworkMod Recovery
volume up or down to move, power button to select once you get in there
-- do a backup under backups/restore, just in case
-- select "wipe data/factory reset", let this finish
-- select "wipe cache", let this finish
-- select "mounts and storage", then "format /system", let this finish
-- select "advanced", then "wipe dalvik cache", let this finish
-- select "install from zip", scroll to the base file and select it
-- select reboot
-- wait for your phone to boot up (will take a few mins, don't panic)
-- when android man shows up, wait 5 mins to let it settle
-- sign in, make sure the 2 checkboxes are checked to restore everything
-- let apps reinstall from the market, set up homescreens and whatnot
-- Do you want blur or not?
-- reboot back into clockworkmod
-- select wipe cache
-- select advance, wipe dalvik cache
-- install whichever add-on you want (blur or not)
-- reboot
-- install whichever theme pak you want
-- reboot
-- REJOICE
ab112885
3
can someone please post step by step on how to load this rom. thank you
You may already know this, but the dev has moved on from this ROM. I haven't been able to find any live links to anything but the ROM itself, which is very bland.
Sent from my DROID BIONIC using Tapatalk
2defmouze
3,945
1,552
I still have from my bionic days my files for the base, AOSP (blur-less) add on, and ICS Tpak... if you guys want I'll put in my dropbox for you, just let me know
LDubs
645
34
28
Go through the most recent posts in the thread on rootzwiki that I linked in my post. Th3oryrom had some issues with whoever was hosting their files and had to start over, but a bunch of folks already posted download links in the meantime.
RandyRoyalty
