[WARN]
[INFO]For those of you using a custom kernel with Build EE4 to gain root and have run into the Write protection pop up when trying to transfer files to your sdcard.[/INFO]
sdcard patch:
[NOTE]All credit to Kejar , so please remember to thank him[/NOTE]
Android Central, Kejar, nor I are responsible for anything you do to your phone so as always use with care
[/WARN][INFO]For those of you using a custom kernel with Build EE4 to gain root and have run into the Write protection pop up when trying to transfer files to your sdcard.[/INFO]
sdcard patch:
- simply download below
- place on sdcard
- and flash using clockwork
