Looking for some wisdom from this group <G>, as I have searched high and low and googled for days looking for anyone else with the same problem. My Fascinate has the latest update available (Android 2.1, Update 1/DL09). However, I'm now on my second Jabra Cruiser Speakerphone and still cannot use it hands-free. I can stream audio to it, but none of the buttons on the Cruiser work: pause, fwd, rewind, or the call answer button--they only beep when you press them. So much for hands-free. I have gone into Verizon and Best Buy, then called Jabra, and called Verizon (who contacted Tier 2 support). Verizon couldn't find any issues between 2.1 or the Fascinate and this unit. Jabra has heard of some "issues" (but not my exact issue) and would only suggest updating the phone's firmware. I had already unpaired, pulled battery on phone, all the usual stuff. Finally BestBuy let me exchange the unit for another one, as everyone seemed to think maybe it was faulty, but I'm having the same problem today with the new one. No one can tell me if the phone might be faulty, or if Android 2.1 doesn't have the proper BT functionality yet until 2.2 comes out. The Fascinate is supposed to support A2DP for streaming and AVRCP for remote control. The closest I came to finding an answer was someone mentioned that the iPhone had a similar problem. Any help would be appreciated.
