Pop up with: this language is not supported
kelin84
4
Hi, I've just revived a Samsung s20. I installed it with Danish language. I was surprised that it suggested Polish....
I'll keep getting a little grey pop-up saying: "this language is not supported" it will dissappear by it self, but it's very irritating to me.
I thought of a factory reset, but then I was thinking, how much it's actually are reseting, is it just back to where it was when I received it, or is at deeper reset?
So here is my theory. It's allowed to import from other EU countries, normally I would check that it wasn't importet, but I had my guards down on this one.
So I think that it maybe was imported, and that's why it suggested Polish to begin with, and somehow something is still stuck.
When I look at my one drive allowed notifications, 3 lines are in, what Google translate think is from Bosnia.
I've tried to Google, deactivate Google assistant, delete all apps, I haven't used before. But I don't know where this error is coming from.
Do you think a factory reset would work?
Do you think my theory is correct?
Or do you have any other suggestions?
I don't even know of this is an android issue or Samsung.
If you just got it, and think it's a problem due to the selection you describe making, a reset isn't a bad idea at all. Good luck
Welcome to Android Central! Samsung has been known to limit the available languages on regional phone variants. I think the only way to get more languages would be to flash a different firmware. @mustang7757 might be able to provide more insight into this.
Is this a US version s20? You choose a different language for the phone? And which app is that you posted ? It only happens with that app?
TaiTheGuy
