Android (Samsung, Pie) read onlys my sd card. It says it does to protect me, but Android is stupid. Most sd cards are formatted fat32. Dumb Android doesn't know fat32 4GB file size limit. Android thinks the file allocation table is corrupted. Is there a fix for this Android/linux bug? Will Samsung provide an update? Seems Android issue as desktop Ubuntu file manager tells me the space on destination won't fit and simply stops operation.
