how to save text conversation
arickinreallife
Active member
May 4, 2012
32
how can i save a text message conversation from the stock messaging app on my htc one s?
i need to be able to print it for court document proof
The only way I would know is take screen shots and then use a dropbox Google drive sort of thing get them on a computer and print
Sent from my SCH-I535 using Android Central Forums
You can download SMS backup and restore from the Google Play store and save to the sd card(or the internal storage if it doesn't have an sd card slot.
grastyvirginia200
