android wont boot
lshorter2251
6
When i turn my tablet on i get a battery symbol with a triangle around it and exclamtion mark in middle
what can i do to fix this please help
let it charge for a while and then hard reset... I have seen many having this issue and it due to battery being out of charge or low..
i did let it charge and it finished charging and tried hard reset and still get same thing
I know its a tablet but any chance its has a removable battery? if yes, remove it and place again.
how did you hard rest because every manufacturer has different hard reset steps.
what tablet do you have?
F10 Android 4.0 7 inch Capacitive Tablet PC 2160P Video External 3G 4GB
and the battery is soldered to board and i reset using the reset button and also tried the power button and up volume but still get same
How old is the device? Have you considered calling their tech support to see what they say?
amateur_user
