How to stop music from going to the next track when finished
pyromnt
Hi, I am stage managing a show and have all of the sound cues on my Droid 4
The only problem is that I am using 'My Music' and when cue finishes (say a gunshot) the next begins (say a fog horn). This is very problematic
They all under the same album 'download'
What can I do?
Thank you
Devinator
Sūpā Saiya-jin Fō
Jul 27, 2011
3,000
147
Create playlists with each individual sound you want? That way there is no proceeding audio file played.
Mooncatt
Ambassador
Feb 23, 2011
10,759
321
83
Either make separate play lists with only one sound in each, or edit the tags so they are on different album names. Then when you browse by album, it only pulls up the one cue.
