Serious question for net10 and ST!
benzgod69
Okay. I had an old ST phone. Recently bought a net10 phone. I wanted to know if I could switch the Sim Card from the ST phone to my net10 one. Since I don't like Net10 as much as ST. I just wondered will this work? Can it work? Would I waste money buying a ST card?
No you cant use a ST sim in it. Even though ST, N10, and Tracfone are basically the same, each one is designed for its own network. You could unlock it, but depending on the phone it might or might not be worth it
Buka Blokir Wondr BNI
