Why can't I show my current location in Google Maps using Android?
sudhakarcse11
I cannot able to show current location in Google Map using Android
I am using GoogleMap application in that i need to show current location,i am using Location Manager class to get latitude and logitude points , i done everything correctly but i had error in locat FATAL EXCEPTION..
here my error page...
Re: I cannot able to show current location in Google Map using Android
Are you sure you aren't using an uninitialized variable somewhere? That would crash just about anything. (Or misusing a variable, so it walks over another one.)
pratikkumarBB
