Hi there, I know people had this issue after the 4.4 OTA update last November but I have it now
I did drop it a short distance this morning onto a carpeted floor, it seemed to work fine till I turned wifi on, it would just turn off again, without displaying networks. I rebooted and ran into the endless loading screen issue.
After reading about people having these issues because of connecting components incorrectly after repairs, I wonder if its hardware related.
I reset cache(had those cache errors) and factory reset before I thought of this though :'(
That didnt work, still loading endlessly. I read about recovery software(wugfresh?) to try and flash a stock image. My phone doesnt connect via usb though, I used to turn that on manually when I needed(hope that didnt turn out to be a huge mistake now).
So, is my device soft bricked? Im thinking of trying the wugfresh app to flash a stock image, seems to be my best option.
Any advice on how to proceed would be appreciated, thanks O
EDIT: I cant use wugfresh root kit since its not connecting VIA USB
