how to reinstall OS after wiping my nexus 4
actually it is more complicated than that.
i first flashed it to TWRP (no problem).
after sometime i want to flash it 5.0.1 lollipop.
i used nexus root toolkit 1.99. the flash seemed to failed.
it is still 4.4.4, but all 3 virtual key at the bottom does not work anymore.
then i tried to factory reset. no go. then my stupidity kicked in. i booted into twrp and wiped the phone.
now when i boot up the phone, it is stuck in the google logo, and nothing came up anymore.
help is very appreciated!
