Shimil
Welcome to Android Central! If you don't have that option, then it's not the cause. Have you already tried the usual things to fix it, like rebooting, or clearing the YouTube app cache/data?
No more way?
Are you saying you've tried that?
Not sure if this will help, but go to Settings>Developer Options (if you don't see it, then go to Settings>About Phone, and tap Build Number 7 times). Then switch the media player--if it's set to NuPlayer, change it to AwesomePlayer, or vice-versa. Now see if the problem persists.
My probably is I can't find that on my galaxy s7, any answers for that?
Welcome to Android Central! Not all devices on Lollipop have the NuPlayer vs. AwesomePlayer setting in Developer Options.
Does the sound only become unsynced when you go to fullscreen mode, or change orientation?
Welcome to Android Central! Did you read the above posts?
I have a TCL andorid tv and its youtube keeps on stop working whenver its connected to sony dv650 home theatre via bluetooth. what could be the remedy?
When i play video from YouTube, sound and video are not in synced. Let me know how to fix it.
Thanks in advance!!
