YouTube app sound is delayed. How to fix it?
A
AC Question
When i play video from YouTube, sound and video are not in synced. Let me know how to fix it.
Thanks in advance!!
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
Welcome to Android Central! Which device? Have you checked the same videos on your computer? I've noticed that some YouTube videos have that lack of synchronization as a flaw in the video itself, not of the device.
Tommy L1
Hi,
I have Samsung S6 Edge and notice same problems with delay in sound when i check youtube.
I have a Iphone and checked and no delay on the iphone but seeing the problem with the Samsung Phone.
It would be nice to have more people looking for this because its quite anoying.
I have reset phone and also emty chache and done all i can to eliminate the problem but nothing works.
Its not a huge delay but you see it quite easy if you just look for it.
/TL
Love the phone in all other areas...
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
Not sure if this will help, but go to Settings>Developer Options (if you don't see it, then go to Settings>About Phone, and tap Build Number 7 times). Then switch the media player--if it's set to NuPlayer, change it to AwesomePlayer, or vice-versa. Now see if the problem persists.
Lonns
Hi this seems solving The problem i had. Really thanks for The help.
armhieko
Hi,
/TL
as b.diddy said.. Settings>Developer Options (if you don't see it, then go to Settings>About Phone, and tap Build Number 7 times). Then switch the media player--if it's set to NuPlayer, change it to AwesomePlayer. then restart your device and everything will be back to normal :) i did it on my s6 edge and it really works thnks b.diddy
genuhvi
Hi! I cant seem to find the media player option when im at the developer options. I am using a galaxy note 3. Could you help advise on what i could do?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
Welcome to Android Central! Not all devices on Lollipop have the NuPlayer vs. AwesomePlayer setting in Developer Options.
Does the sound only become unsynced when you go to fullscreen mode, or change orientation?
hipkatt
Where are we supposed to click on settings? In the Youtube app? I have a samasung Galaxy tab (4 or 5 I forget) that has a lag problem
hipkatt
to clarify, you need to go to your device settings, not youtube settings. This confused me at first, i thought i needed to go to the Youtube settings. Once i realized it was the device settings, it seems to have fixed it.
Apr 27, 2016
What if there's no NuPlayer or AwesomePlayer or etc on my phone? My Youtube's always delayed. :( Help me.
