Notification Issue after rooting my device, what should I do?
TaRT zKie
Banned
May 25, 2015
71
Hi guys,
I need your help.
My problem is I can't receive any notification from my messenger (like viber and whatsapp), sometimes it's delayed after rooting my device. I need to go the particular apps to check whether they replied or if I have a new message. I've checked everything settings,connection of wifi even I used mobile data connection and try to uninstall and installed it again but still the same.
I want to know if this case is usually happened to other device when they root their device.
Waiting to your kind response!
