Hi Internet,
I was trying to flash Android M on my Nexus 9 (Wi-Fi only) today and ended up with errors such as: "system.ui has stopped working" or "android.process has stopped" because I wanted to see if I actually needed to do a factory reset for it to work properly (turns out I do). After that I've tried again and have run into some issues.
Firstly, after that Android M wasn't flashing at all and I have decided to abandon the idea of M and just go back to Lollipop. Now, I am trying to flash 5.1.1 and I keep on getting FAILED (remote: data length is too large) error when flashing my system partition. I'm flashing everything separately because if I try to do it as one image because I keep getting error: update package missing system.img errors. I have no trouble with flashing my bootloader and other partitions(boot, cache, recovery, etc), but that system partition just won't flash! I've tried 5.0, 5.1, 5.1.1 and I keep on getting these errors.
I have no idea what to do. Please help. I've spent the last 5 hours trying to figure it out and nothing has yet came up. I'm using a Mac, but I don't see how this might be causing an issue. If you have any valuable information - please help!
I'm very comfortable with flashing and ROMs, in fact I've updated my N5 to M in 5 min, but I've never seen this error before and have no idea how to fix. All I found out is that, I think, it only happens on HTCs...
