How does the reject call feature work?
cyberwasp
Active member
Jun 23, 2015
35
reject call feature
an LG Vista.
In my call logs there is a reject calls feature under the drop down menu. By any chance will that prevent a call from ringing the phone if it calls again. My old moto razer had a similar feature that I miss. TIA
Re: reject call feature
an LG Vista.
Welcome to Android Central!
If you put a number in the reject list it will send the number to voicemail every time.
amateur_user
