A
AC Question
Removed apps keep reinstalling themselves
Okay, so. This is not my tablet, I am trying to fix it for someone else. the tablet in question, a Fondi T708B has some sort of app installed that:
* Keeps reinstalling itself
* Downloads and installs other apps automatically.
The stubborn apps seem to be called TimeService and Monkey Test. I have looked up other threads online and found multiple users claiming they are not able to get rid of these apps AT ALL. I have tried the following:
* Disabling install from unknown sources.
* Disabling automatic updates.
* Various anti-malware and -virus scanners (Malwarebytes, 360 Security etc).
* Disabling the Google account automatic backup.
* Factory restore
The anti-malware scanners also picked up malware in the following:
* com.android.provision.confirm
* com.nb.superuser
* Setting Provider
Since the issue is prevalent right after doing a factory restore, it leads me to think the default rom already has this issue or something is not wiped when the factory restore is done (lots of user files still remain it seems).
Any help would be much appreciated.
Malan.
* Factory restore
* com.nb.superuser
* Setting Provider
Malan.
