How do I prevent a resizing issues when running apps?
  • Start date Start date
A
AC Question
I have an LG phone. Quite often when I am running apps, my screen resizes and enlarges. When this happens I have to either a) restart my phone because it is frozen, or b) tap the screen a bunch of times and hope it resizes back to normal. How do I prevent this?
I am not sure what the issue is, it most often occurs with 3'rd party apps.
Re: How do I prevent resizing issues when running apps
Welcome to Android Central! Go to Settings>Accessibility ​and make sure none of the options are turned on.
probang
