Can i Flash lollipop Rom on S3 GT-I9300 ?
pakisgr8
when i bought my s3 gt-i9300 it was running 4.3 jellybean i rooted it and installed almost 5-10 roms(including jb and kit kat roms) and network worked fine with all of them.
Then one day i installed chainfire 3d and ended up with a soft bricked device i brought my phone to a technician and he flashed official rom with odin but it was a 4.1jb and he voided my phone's imei and network was gone he did something again and phone was registered on network.
I used 4.1 some time and then flashed a custom rom ANDROID REVOLUTION HD v52.0 4.3JB and network was gone again then i flashed
XXUGMK6 Modem.zip and XXUGMK6 Kernel.zip with CWM recovery . and network issue is fixed.
Now My Question is
AM I bound to use android revolution hd rom only ?
bcz if i flash any other rom(even jelly bean) network is gone again and that method does not work i want to flash CM 12 5.0 or any other lollipop rom on my device.
Is there a way to solve this problem ? plz help thanks
richardgroover
