1. AC Question's Avatar
    with a android phone
    11-10-2015 09:38 PM
  2. Liz Ford's Avatar
    Try holding the power button and the home key at same time...also depends on ur phone...some work by sliding edge of your palm across your screen right to left and back...took a few times of doing this to work on my edge...
    11-10-2015 10:04 PM
  3. Liz Ford's Avatar
    Ps...the palm edge way is difficult I literally just tried and tenth time it worked I mean you can barely touch screen and I have to do it quickly...this time it worked left to right and back..you should find answers in your phone...under camera but then again I cannot find my bookmark folders anywhere so some things are a mystery
    11-10-2015 10:10 PM
  4. hallux's Avatar
    I believe both methods mentioned by Liz are for Samsung devices. For Motorola and nexus devices (at least) the method is to use the power and volume down buttons at the same time.
    Laura Knotek likes this.
    11-10-2015 10:41 PM
  5. Liz Ford's Avatar
    Thanks hellux...you are right I only know if samsung ways unless the shake method works...it did for one of mine that wasn't a samsung...smiles
    11-10-2015 10:47 PM
  1. How do I do a hard reset on my son's Samsung Galaxy Tab 3 kids?
    By AC Question in forum Samsung Galaxy Tab 3
    Last Post: 07-03-2016, 03:12 PM
  2. how to return to watchface when clearing a notification?
    By aweber1nj in forum Android Wear / Wear OS
    Last Post: 11-16-2015, 06:07 PM
  3. how do i download the amizon app store on my android trio
    Last Post: 11-10-2015, 10:46 PM
  4. What do I do since my Tablet won't hold a charge?
    By AC Question in forum Misc. Android Tablets
    Last Post: 11-10-2015, 09:04 PM
  5. How install Amazon APK on Nexus 4, 5.1.1
    By mawil1013 in forum General Help and How To
    Last Post: 11-10-2015, 09:01 PM
