I have an 18" Galaxy View (1920x1080 Lollipop 5.1.1) coupled with a Microsoft Designer keyboard and mouse (Bluetooth). I'm trying to use VnC Viewer Android to connect with my home computer (dual monitors both at 1920x1080), one running Windows and the other Linux (WMaker).
There doesn't seem to be any way to establish a direct connection between the bluetooth mouse running locally and the remote host in either VnC or TeamView. Local mouse movement does move the remote mouse pointer but it's like the local mouse has an abstraction layer that converts it's movements to "simulate touch" movement instead of passing the mouse movement directly to the remote host and right clicking brings up a local disconnect question instead of a remote context menu.
Is this an Android OS API issue or an application understanding issue? Perhaps Android isn't mature enough to properly handle rodents.
