hey guys, i hope you can answer this question for me.
I was wondering if you could tell me what exactly a custom ROM does for you; cause it seems like most of their benefits actually come from the launcher you choose:
LAUNCHERS let you:
*change your theme(graphics and animations)
*change your icon/app drawer layout
*get new widgets
*adds power control settings to the notification shade
ROOTING lets you:
*remove carrier bloatware apps
*gets you access to the filesystem(not too sure about the benefits of this)
ROMS let you:
*change your kernel(for battery life)
*allows for overclocking(by changing the kernel)
*removes the carrier/manufacturer skin(but doesn't the launcher do this already?)
is there a ROM that duplicates the STOCK android experience? essentially turning your non-nexus phone into one: the same performance, default apps, and graphics.
LAUNCHERS let you:
*get new widgets
ROOTING lets you:
ROMS let you:
