Why the file is not uploading correctly?
  • Start date Start date
A
AC Question
I am trying to upload a file from my mobile to the database server.
The file is uploading successfully.
But the file which is uploaded in to the database its storing empty file.
The size of the file uploaded is 35 MB, but in database is shows 0 MB.
Welcome to Android Central! Is this some kind of cloud service, a server you set up, or something for work?
Are you able to narrow the problem down to the Android device, or could it be an issue with how the server uploads files?
Right--so I'm wondering if it's possible to narrow that down to a problem with Android or a problem with the server.
Are you able to test uploads from other platforms (like iOS or Windows)?
By the way, this will probably get out of my scope of knowledge pretty quickly.:-\
Toxxyroxy
