A couple of days ago I started getting these messages whenever i try to do something on my phone (write a message, go on facebook, call someone) so it's really annoying because they keep poppin' every 3 minutes : 'INSTALL BLOCKED. For security, your phone is set to block installation of apps obtained from unknown sources.' The blocking installation is for apps that i have never heard of such as: APUS, Bubble Sea Saga, Fruit Defenser etc. I don't want to modify my phone settings because these apps may be a virus and i don't want them. I mention the fact that i installed apps on my phone from Play Store only.
I did a factory reset and i installed back on my phone all the apps. All went well for a day and a half, and now i'm starting to get the INSTALL BLOCKED message again. Rarely at first, but now more often with every hour.
I don't know what could be the problem. I don't have any suspicious app installed on my phone. All of them are from Play Store. I also did an antivirus scan and nothing was found.
What else can i do? I don't want to send my phone into the service for 2 weeks (as the company from where i bought the phone suggested).
Thank you in advance.
03-09-2016 06:29 AM
