no message. help!.its as if the message disappeared.
smlud1
When i get a message I get a notification but there is no message in hangouts or when I use messaging its as if the messages dissappear after the notification.
I have seen similar if the message was actually an MMS and you do not have a correctly configured APN.
Who is your cellular carrier? What device are you using?
MichaelCrusan
