No notification on lock screen
Also try this. Choose a STANDARD cover screen home card (i.e. clock) and don't use the Good Lock one. Does that show the orange dot? If so, it's a bug with GoodLock modules. You can try adding a notification widget there too if you choose one of the 'informative' cards which will let you add a few widgets there. On mine, if I don't select a card with that widget, I get the orange dot. If I use a card with a widget, I get that widget on AOD instead.
Reactions: Laura Knotek
Well I'm going give you couple more steps to try and outline them for you .
1. Go to settings>apps>tap 3 dots upper right corner and reset app preferences, this will reset anything that didn't go well with the transfer if you had made anything customized in any apps they will be reset to default.
2. Go to settings>general management>reset>reset all settings
This can potentially fix issues like your experience.
Thank you, tried these fixes-- nothing. I have been searching for fixes online and in more than one place I have seen people comment that the little notification light feature is no more with UI 8. So perhaps that's the problem. I did try a couple of notification apps but they're all wrong.
Reactions: mustang7757
That's not true. Again, not sure where things are going wrong, but if I activate all notification options and turn on AOD, I get the orange dot on both AOD and the main flip cover card (or a notification icon if I'm using a home card with a notification widget).
Welcome
Something not right, maybe stop by a carrier store or Samsung experience shop for further help as they can see the device in hand.
Looks like that video is only for the Flip6. The instructions do not coincide with what shows up on my Flip7.
There has to be something similar. I had the orange dot yesterday until I changed to either card style and/or brief so I could get the little icons to appear on the AOD. I had gone though so many settings changing my phone i couldn't remember what I did by the time I saw your post. I wanted the icons instead of the orange dot.
Did you ever figure this out? I came across the setting tonight while changing my cover screen and tested it out.
So press and hold the cover screen. Open the phone to modify the wall paper. You will either see the icons at the top, the dot, or a plus sign on the center left. Click or double click on either the icon widget or the plus sign.
You will get a pop-up for none, dot or icon. Choose dot and you will get the orange dot back.
MichaelCrusan
